Kappa SW rear top mounts
Kamazas
Post autor: Kamazas » 26 mar 2023, 21:32
Hello, maybe someone could tell where I can buy new rear schock absorber top mounts for my '99 SW?
faraon
Skype: nie używam
Re: Kappa SW rear top mounts
Post autor: faraon » 26 mar 2023, 23:08
It is impossible to buy new. Ask at autosklep24.pl - they have the option to change the nivomat to the usual one.
There is a link to the store above
Kamazas
Post autor: Kamazas » 27 mar 2023, 7:11
Does all SW's have nivomat as standard? I think mine one has usual suspension.
faraon
Skype: nie używam
Post autor: faraon » 27 mar 2023, 8:40
All SW had nivomats as standard. Maybe someone has already done a conversion for you. Just be careful, because the springs for nivomats and ordinary shock absorbers were different (diameter at the bottom).
You need a top mount... It must be a miracle :) to get a new one like this. I converted the upper mount to a two-part one, as it is in sedans after the facelift.
skopin
Imię: Adrian
Post autor: skopin » 27 mar 2023, 9:44
are you looking for these?
1 Fiat Bravo 02' 1.6 16V
2 Lancia Kappa 97' 2.0 20V VIS sedan
3 Lancia Kappa 99' 2.0 20V Turbo sedan
4 Lancia Kappa 99' 2.0 20V Turbo sedan 5-7szt
5 Lancia Kappa 98' 2.0 16V Turbo coupe
5 Lancia Kappa 97' 2.4 VIS coupe
1 Lancia Kappa Coupe 98' 2.0 16V Turbo
2 Lancia Kappa Coupe 99' 2.0 20V Turbo
3 Lancia Kappa Coupe 00' 2.0 20V Turbo
4 Lancia Kappa Sedan 00' 3.0 automat
5 Lancia Kappa Sedan 97' 3.0 automat
6 Lancia Kappa SW 00' 2.4 JTD 6b
7 Lancia Kappa SW 99' 2.0 20VT Rosso Nobile
8 Lancia Kappa Sedan 99' 2.0 20VT
Kamazas
Post autor: Kamazas » 27 mar 2023, 13:31
skopin pisze: 27 mar 2023, 9:44 are you looking for these?
I think so.
Kamazas
Post autor: Kamazas » 27 mar 2023, 13:32
faraon pisze: 27 mar 2023, 8:40 All SW had nivomats as standard. Maybe someone has already done a conversion for you. Just be careful, because the springs for nivomats and ordinary shock absorbers were different (diameter at the bottom).
Where could I learn more about the conversion?
faraon
Skype: nie używam
Post autor: faraon » 27 mar 2023, 17:42
To change you need:
1. bracket - see photo
2. pillow - photo
3. new type shock absorber (with short upper thread)
4. spring for sedan
Kamazas
Post autor: Kamazas » 27 mar 2023, 18:20
Where could I get the bracket or it's only available used?
faraon
Skype: nie używam
Post autor: faraon » 27 mar 2023, 18:46
Kamazas pisze: 27 mar 2023, 18:20 Where could I get the bracket or it's only available used?
I don't know. You have to search.
Kamazas
Post autor: Kamazas » 28 mar 2023, 13:47
I have one more question. Will the old type top mount from sedan fit my nivomat shocks?
faraon
Skype: nie używam
Post autor: faraon » 28 mar 2023, 17:15
If no one has done the conversion, it should fit as far as I know.
In all SW kappas the factory upper mounts were 99% of the same (old) type.
Kamazas
Post autor: Kamazas » 28 mar 2023, 19:24
But if the old mount fits SW, why the old type schock absorber doesn't?
faraon
Skype: nie używam
Post autor: faraon » 28 mar 2023, 19:33
Old mount => old type of shock absorber :!: :!: :!:
Earlier I wrote that if you change :!: the upper mount to a new type, you must also have a new type of shock absorber.
Kamazas
Post autor: Kamazas » 28 mar 2023, 19:46
So it means I could use fully assembled old type sedan dampers. Thanks, got it.
