Kappa central locking
Kamazas
Post autor: Kamazas » 18 kwie 2023, 11:45
Hello, I have a strange problem with central locking. Cant lock the car, as soon as the car locks it unlocks itself, no matter if I use remote control or try to lock with a key.
skopin
Imię: Adrian
Re: Kappa central locking
Post autor: skopin » 18 kwie 2023, 13:46
it may be the fault of the yellow relay, which is behind the flap in the passenger footwell
1 Fiat Bravo 02' 1.6 16V
2 Lancia Kappa 97' 2.0 20V VIS sedan
3 Lancia Kappa 99' 2.0 20V Turbo sedan
4 Lancia Kappa 99' 2.0 20V Turbo sedan 5-7szt
5 Lancia Kappa 98' 2.0 16V Turbo coupe
5 Lancia Kappa 97' 2.4 VIS coupe
1 Lancia Kappa Coupe 98' 2.0 16V Turbo
2 Lancia Kappa Coupe 99' 2.0 20V Turbo
3 Lancia Kappa Coupe 00' 2.0 20V Turbo
4 Lancia Kappa Sedan 00' 3.0 automat
5 Lancia Kappa Sedan 97' 3.0 automat
6 Lancia Kappa SW 00' 2.4 JTD 6b
7 Lancia Kappa SW 99' 2.0 20VT Rosso Nobile
8 Lancia Kappa Sedan 99' 2.0 20VT
Bichoń
Post autor: Bichoń » 18 kwie 2023, 22:55
There's a micro switch in each locking mechanism to detect if the doors are closed and locked. If it can't detect "locked" position then locking central unit in unlocking all doors. You need to check those switches.
Kamazas
Post autor: Kamazas » 19 kwie 2023, 13:45
skopin pisze: 18 kwie 2023, 13:46 it may be the fault of the yellow relay, which is behind the flap in the passenger footwell
How can I find it?
Kamazas
Post autor: Kamazas » 19 kwie 2023, 13:46
Bichoń pisze: 18 kwie 2023, 22:55 There's a micro switch in each locking mechanism to detect if the doors are closed and locked. If it can't detect "locked" position then locking central unit in unlocking all doors. You need to check those switches.
How to check them?
